My Ford Touch Sync Update Gen2-V3.7
mridahodan
The patch fixed mine as well. I don't seem to have the location issue, but I have not used the GPS much since patch. I'll keep an eye on it and report if it has the same issue.
CGERM
Westchester County
The Sync folder and the two files that are in the Patch folder need to be in the root directory. Just drag them out of the patch folder and put them on the drive letter of the flash drive, then delete the patch folder when it says it is empty.
This happened to me also and this is what made it work for me.
I just wanna thank you @pat247 & @FordIVTteam cause the patch worked
Don't ask me why but I guess they didn't have to be in a folder on the usb drive just the 2 files and the sync folder on it. Only if I had thought of that the first place
Before:
https://vimeo.com/114934330
After:
https://vimeo.com/114934201
pat247
Oklahoma
CGERM I'm glad it worked, as I said I had some of the same issues with the install. As far as the GPS being off, I have not experienced this but I have only viewed the map a couple times while driving around. I will enter an address and see if it makes any difference the next time that I go somewhere in the Raptor.
CGERM
Westchester County
@pat247 since the update I have not noticed any of the maps being off. Was this after the patch or right after 3.7?
mwakgp
Bend, OR
Hey everyone,
I'm just stopping by to let you know that Ford has created a patch to revert the Ford splash screen back to the Raptor image (for those of you that have installed V3.7). This fix can be downloaded from: http://syncmediaprod.blob.core.windows.net/swparts/Gen2v37_RaptorPatch.zip You must extract the downloaded .zip file and place the extracted folder and files on the root directory of a USB drive. Keep in mind that the USB must be formatted to FAT32 or it will not work. Once the USB is inserted in your Raptor, the installation will start automatically (just like the other software updates).
If V3.7 is available for your vehicle at: SYNC Technology | SYNC Support | Ford.com I suggest holding off on the installation until the issue has been resolved.
Kim
Thanks for the patch! I used the same USB stick as last time and it flashed up a message about being incompatible but then worked fine anyway.
medic001918
I noticed it being off after 3.7. It didn't improve with the patch or a reset.
Shane
FordIVTteam
Don't ask me why but I guess they didn't have to be in a folder on the usb drive just the 2 files and the sync folder on it. Only if I had thought of that the first place ...
You're welcome! :)
Yep same thing here.
And yes I have stock wheels and tires. No issues prior to the update.
Please send your name, VIN, phone number, and mileage so I can properly document this. Thanks for reporting!
I'm glad everything is back to normal. I appreciate the feedback. Thank you!
Kim
Svtweb
Westminster, MD
Thank you for the patch.. works like a charm..
Couldn't help but dig into the all the CABS..
I think I may let my nerd-side start playing with creating my own MP4 opening and closing screens...
BigBOSS
Austin, TX
Those were my exact thoughts too
woutvc
Belgium
I tried to install the update today, but it failed. It said "Bad installation file".
I used 4 USB sticks, formatted them all and copied the unzipped files from my computer to the USB drive. All USB sticks failed.
What are my options now?
