GEN 2 My First Truck, 2017 Ford Raptor Supercrew
I
California
Ground
I did similar, same logic, easier to change the outfitter config if I wanted, but I used MUYI who makes a single connector and ran the ground separate. less connections, less fail points.
https://www.amazon.com/dp/B01FP1HXTE/?tag=fordraptorforum-20
Very nice. Both methods work. You must be grounding your lights to individual locations? If I ever have to troubleshoot, all of my grounds and hot wiring is clustered together in parallel.
Frank N
NJ and Outerbanks
Excellent! Single connectors for the positive wires - nice. How did you do the grounds? I've been wondering if there's a nice, weatherproof ground bus solution out there.
Each set of wires is in their own loom, loom ends after battery heading to upfitter power. All my grounds go to the same grounding stud on the inside fender.
flzrider
Thanks for posting the details of your modifications. I'll be checking this thread for inspiration.
I
California
Locking Wheel Nuts
A simple upgrade. I installed the Gorilla Automotive 96644BDX locking wheel nuts. Annodized black, and they come in a 24 pack. I think they look great on the factory beadlock rims.
Gorilla Wheel locks on dirty rims
Stock
I
California
Programming 2018 Ford Raptor FOB
I think someone else on the forum beat me to it, but yes you can program the 2018 Raptor FOB to a 2017 Truck. It’s super simple and easy to do yourself. I purchased the OEM fob and key on Ebay.
2018 smart Key blade not pictured.
Key FOB programming Instruction
- Gather BOTH programmed keys and your new third/fourth key. Start inside vehicle with vehicle turned off and doors closed. Do not touch the brake or gas pedal throughout this process.
- Place the first programmed key in the backup position (most forward slot under center console cup holder).
- Press Start\Stop button.
- At the end of the third start up chime, press Start/Stop button.
- Swap first programmed key with second programmed key (quickly)
- Swap second programmed key with the un-programmed key (quickly)
- Door locks will cycle and dashboard light up signaling the new key has been programmed.
17-18 Ford F-150 RAPTOR Smart Keyless Remote Key Entry F150 Fob Transmitter OEM | eBay
New 164-R8168 OEM Proxy Smart Key Blade Emergency Insert Replacement for Ford
