Music on flash drive Question
64auto
SouthEast TN
Can I take music from my Itunes and put it on a small flash drive so It can be plugged in to USB port?
JuggNuttz
chicago
Harblar
Aberdeen, SD
Got like 500 songs how many gig driver would I need?
Depends on the size and quality of the files.
As for what size you need, go to the folder with your music, select all the files, right click and select properties (assuming you have a PC... Mac your're on your own :biggrin:). It'll pop up a dialog box that will show you the total size of the selected files.
As for quality of the files. If they are mp3's or iTunes AAC files, they'll play fine. If you ripped your music direct from cd's as Apple Lossless (m4a files) they won't play off from a flash drive.
JuggNuttz is right. Bigger is better and (assuming your music is mp3 like) that drive should have enough room for 3-4 times the amount of music you currently have. Plenty of space to fill with more tunes!
Ruger
Northern Nevada
I've got music on a thumb drive, plugged it into the USB port in the Raptor and got nothing. The truck wouldn't even recognize the thumb drive. Same thumb drive plays fine on my computer. I'd love to know why if anybody would like to try to educate a dinosaur.
The Car Stereo Company
here, on frf
whats the format on the drive?
64auto
SouthEast TN
Not that good with the flash drives, so have a few questions. Can i make different folders on the drive and drag songs over accordingly. Then just add more songs as i download them.
Harblar
Aberdeen, SD
Definitely check the formatting of the filesystem on the drive. The sync system will only recognize a drive formatted in FAT32, so you might have to reformat and reload music onto it to get it to work.
Yep. Once plugged into the computer you can use a flash drive just like a regular harddrive. While I'm not 100% positive on folders, I'm pretty sure they will work just fine. Give it a try. If it doesn't, just transfer the files straight to the drive with no folders. (that's what I did.)
Everytime you download new music you'll have to plug the drive into the computer and copy the new files over and then Sync will take a few minutes to rescan your drive. No worse than using an ipod. ;-)
