Morimoto Announces NEW 2nd Gen XB Headlights for Gen2 Raptors
TheTeej
Denver, Colorado
I did not install them yet. Just asking if it is necessary to set everything back to original or if it even matters since power comes from a separate source for the new DRL. Cannot have to much info before starting install.
Thanks
if you did the halo surround forscan tweak, all you have to do is turn off the drl check mark in the dash menu once you install the fuse tap
Raptoe13
Chickasha, OK
Have these headlights had any of the same weak shield spring issues as the regular 2018+ F150 Morimoto Gen2 headlights?
4x4TruckLEDs.com
4x4TruckLEDs.com
I’ve not had any issues personally nor have any of our customers reported issues
4x4TruckLEDs.com
4x4TruckLEDs.com
MAN these things are SWEEEEET
We've got them in stock ready to ship if anybody still wants a set. Just order them here:
http://www.4x4truckleds.com/morimoto-xb-led-headlights-for-2017-ford-f150-raptor-2015-2017-f150/
mattl600
Los Angeles
Do these come out of the box with decent height ? I just installed mine and feel like the passenger side is higher than the drivers (as it usually is) but is seems very pronounced. Also they feel a bit low.
4x4TruckLEDs.com
4x4TruckLEDs.com
No housing is ever setup ready to go out of the box - you always need to align your headlights anytime you change a bulb or housing
mattl600
Los Angeles
For sure.
the manual on site looks like it has the adjustment points only for the first generation.
Are you able to adjust these without removing them?
