Model year 2025 Keypad - early deliveries
Kayslay
BC Canada
I’m disappointed they pulled the key pad for the 25s as well. The dealer said some of bronco guys install them in gas door so that might be a good option
Rick at FMS
aka:Rick @ FreedomMotorsports
SW Missouri
Here is a picture of one installed on a 25' that just came in last week. It looks worse than I thought it would be. I am going to ask the dealer not to install mine. Person who posted this picture is thinking it might fit on the inside of the gas tank lid but others have said it will not. I might put it somewhere else but have it to make a decision later.
cheapo
Oklahoma
So, is the pillar install shown earlier not the included one for a 2025? Is the one above just stick on? I don't love how it looks. I wonder if I could stick it somewhere not obvious if it's a stick on
GTTXRAP
Drill Baby Drill
U.S.A.
That looks terrible...no way I'd let them do that.
Raptorium
Raptorian
North Ogden, UT
Here it is installed. 2025 F150 Raptor, 801A Space white
NOT a stick-on. Pillar Install like previous Raptors. Just not standard on 2025. You need to add it after delivery at your dealer.
jamul
was the intellicode on your window sticker in the security option section? If so, was the master pin code for the key pad in your right side kick panel on a sticker like a normal keypad equipped truck? Mine arrived today and they are waiting the arrival of the molding and key code to do the install as Ford sends that separate for some reason rather than tossing it in the truck for those that opted for it. I am considering taking the truck and having them ship me the parts when they arrive there and doing the install myself but not if it will not be self recognizing/simple to program a code. I have forscan but not sure forscan will do it. It's a 4 hour drive to dealer so going back for install would be pretty gay.
Old-Raptor-guy
USA
There is alot of miss information here.
The dealer installed is a kit that will look and function the same as a 2024.
The sticker/textured one is a Ford accessory for vehicles that did not come wired for a factory install, nor have a BCM that allows for "keyless entry".
They act as a "remote" the code is put in then the key pad transmits an unlock or lock signal to the BCM same as a keyfob.
The wired ones the code is stored in the BCM and the BCM records each input until the correct code is inputed and then unlocks/locks
As for the sticky one I have had one on my 2002 F350 since 2003 and it still works (as of last try and month ago), but admittedly i do not use it that much.
Anyone who thinks this is "old tech" and should die, doesn't understand the usefulness of it.
Old-Raptor-guy
USA
additional $255 plus labor for what it should've been included is crazy
I have done one,(had to replace a keypad on a 2022) it is quite the ordeal and labor won't be cheap.
I would guess most shops would charge 3+ hrs. 4 wouldn't surprise me, anymore than that would probably be excessive.
