battousai
Ah I see. Boo to this. I'll just stick it out then if other people encountered the same problem. Thought it was just me.
Did the update earlier this week and now a weird issue that has happened twice so far since then. It happened yesterday and then this morning before I went to work, the radio shows "Entertainment Off" and you can't press anything to turn on the radio.
Yesterday I just pulled over into a parking lot to turn off and back on the truck which worked. This morning I was like what the heck, I used the voice command and was able to tell it to turn the radio on the a Sirius station and it worked after that. In any case, I may need to schedule something with the dealership to get this fixed so that Raptor start-up splash screen will be a plus.
OK, dealer got same results as me, so they disconnected the battery and then reconnected, then it took the update.
So if this happens to you, before you go to the dealer, try the battery disconnect for a reboot of the MTF.
