wheelman55
Yes. I've been using it on two oil changes so far. About to be my third in a few hundred miles.
Thanks. I picked mine up yesterday with 26 miles on it. Will use the filter you've recommended.
hold the throttle on the floor and press the start button. This will cause the motor to spin over but not fire. You press the start button again to get it to stop turning over. I did this three times for 3-5 seconds each in order to get the new oil pumped into the filter and oil galleries before I started it for real.
Just hold the throttle at WOT without touching brake pedal? Just a little nervous of the engine starting up and revving up all hell! LOL , just wanted to clarify on this very valuable information.Thanks!!!!
What this does is the PCM shuts off fuel delivery to the injector so it does not fire.
TOriginally Posted by BurnOut View Post hold the throttle on the floor and press the start button. This will cause the motor to spin over but not fire. You press the start button again to get it to stop turning over. I did this three times for 3-5 seconds each in order to get the new oil pumped into the filter and oil galleries before I started it for real.[/QUOTE said:I don't see the logic in this. Seems like the oil would start to be lifted from the sump to the oil pump but then when you stopped cranking it most would drain back to the sump with very little reaching the filter. I have always just started the motor and the oil pressure builds almost instantaneously; do this with the Raptor and have done it for many years on other vehicles. I think the way suggested above would cause more damage than just starting the engine.
See attached.
Turning the motor over without it firing is much gentler on parts than having a cylinder (or 6) fire off a few dozen times on dry bearings (well, bearings with only oil film on them, anyhow). Additionally, there really isn't enough air moving through the hot side of the turbos while you're cranking to get 'em spinning at significant RPM... so cranking without firing to get the filter/galleries filled and up to pressure is your best bet for minimizing wear.
During normal cold starts, it's the anti-drain back valve in the filter that keeps the oil in the galleries, ready to lubricate everything as soon as the motor spins over more than a few times.
