Maxxis Razr MT 35/13.50/17 on stock beadlocks
tlnt60
Arizona
Did you by chance try these before the spacers? I’m running the 35/13.5 on my bronco and wondered if they fit without spacers.
They will not clear the suspension without the spacers. You could get away with smaller ones, but would have to cut the factory studs to accommodate (something I didn’t want to do), but going any less than 1.25” or maybe 1” and while the suspension might clear, the tire will rub in the fender due to the added width and changed offset. I too was not a fan of running a spacer, but after much research and speaking with the local 4x4 shop, running the BORA 1.5” spacer and doing a proper install (following BORAs instructions), the shop assured me that they are safe to run. Since the install, I have taken several long trips, 2 pretty rough off-road trips and have put 4k miles on them without any issue. I’m due for tire rotation so the studs will get checked again here really soon, but I expect to find no issues, if anything comes up, I’ll report back here!
ljn21
Tega Cay, SC
I leveled it with collars (1.5”) and used BORA 1.5” spacers all the way around.
Is the level required to fit the 35x13.5 or just the spacers to move the wheel/tire out? Was hoping to not level. Also, could you post pictures of what you trimming?
tlnt60
Arizona
not sure if level is required, but I had mine leveled prior to deciding to put in the 13.5s. Yes, I’ll get a pic later today for you
dromayn
just want to get some feedback regarding tire/road noise as well as durability of the tire. thinking of getting the 12.5 version instead of the 13.5
