Korey
I own a tire shop so take this for what it’s worth- 13”+ wide tires on an 8.5” wide wheel is ridiculous. The bulge that will occur is way too much, makes the tires look and act funny. Not to mention if you air down at all you are really stressing the bead of that tire, it’s already squished now you start to flex it.... If you want to run a 13.5” wide tire you need to be running a 10” wide wheel. That said, I’m running 37/12.50 on a 0 offset 9” wheel with the eibach 2.5” spring and it rubs hard. If I was running a more stock offset wheel, +34 on 8.5” or +20 on 9”, then the rubbing probably wouldn’t occur
