The armrest is easy to remove and I looked it over really well and nothing will be much different from the video that was Just posted. The video just posted will be posted along with the instructions! Here is disassembly with pics
Console lid taken off. And taking off the hinge. The Lid unbolts from the truck with 3 torx screws.(I can't tell you what size torx because the numbers rubbed off of my bits) here's a pic of the hinge being taken off. Its held with 4 Phillips screws (be careful not to strip them)
The hinge lines up with 2 little pins in the lid. It just lifts up and out
Now well remove the cover with the "MP3 player" holder, "cell phone" holder, and pen holder... Its held in by 6 torx screws. It lifts up at the back first then you pull it straight back. There are 2 small plastic tabs that align it into the latch in the front. Don't break them! Ha Ha Ha
Then remove The latch with 1 torx screw and you are done!
Now the fun stuff is to come! Go ahead and go pick up 3M spray adhesive and about 8-12 plastic clamps! On ours, contrary to the video, the back where it hinges actually curves up around where the hinge goes. So I would cut a slit in the corner like its done on the video then clamp the two sides then middle. The front where The latch is, is curved rather than a 90° corner. You should be able to just wrap straight over it. I'll find out soon enough. Oh and the side will be different because ours curves rather than how the lid in the video is straight on the sides. I'll show you What I'm on about-
So with all that said, this should be very very easy to wrap if You follow the video and do it slowly and carefully. Any questions or additional pictures of disassembly may be requested but I assure you it is VERY easy!
Sent from my DROID RAZR using Tapatalk
---------- Post added at 12:58 AM ---------- Previous post was at 12:47 AM ----------
Found something new out! The stuff that currently covers the lid comes off! It will provide tons of more room to wrap the leather over!!! I was showing dad The lid and I felt an edge come up so I took It off. It Takes a little work because its on there pretty good but nothing extreme. Here's some pics of the new gap without the padded cover!
