Luminix edge (v2.0) and Luminix (v1.0)
marsh1
I just took it out last night for the first time. I will get some pics at night but it is very effective. I had a Rigid 50" RDS on my Wrangler and this does not have the crazy throw but seems almost as effective for much of the short range I will be using it for. Is sure is a slick and rock solid mounting system.
ChevTillNow
PNW WA
I just took it out last night for the first time. I will get some pics at night but it is very effective. I had a Rigid 50" RDS on my Wrangler and this does not have the crazy throw but seems almost as effective for much of the range I will be using it for. Is sure is a slick and rock solid mounting system.
Look forward to some night shots of just that bar, and then your other lights in sequence as well. Thanks in advance!
lottp
Hi,
I'm John Trischler. I'm the one who designed the special mounting system and install kit for the new Raptor with the putco luminix light bar kit for the raptor.
So OBXRAPTOR17 contacted me through the eBay link and asked about the kit when one of you posted the link.
So, I can clarify a few things and hopefully it will make more sense.
On the pricing, PUTCO has a MAP price (minimum advertised price policy) on the 40" curved light bar at $1,033 (but it actually just went up to $1,085) for the light bar alone.
So the pricing I had for it was $1,033 plus $150 for the full install kit for a total of $1,183.
So the install kit isn't $300 and it isn't just brackets (I'll be more detailed below)
Sometimes you may find a lesser price than the $1,033 or now $1,085, but they aren't authorized dealers and they may or may not be able to transfer putco's 3 year warranty which is included on the light bar itself. Another thing I have seen is, dealers advertising the entire model line of Putco light bars in smaller sizes, flat and curved and they show the lowest price of the smallest cheapest bar and when you go to add it to cart, you select from a drop down the size and model and the $1,033 price comes up. So it can be confusing sometimes.
The manufactures have map pricing to retain their products value and are usually stern on voiding warranties to non authorized sellers buying bulk and advertising for less.
So, all that said, let's get into the details of the actual install kit. The kit is not just a pair of brackets. However, the brackets are professionally manufactured and design patented pending for this specific application. The brackets are designed by me in cad, and plasma cut and powder coated.
The kit contains both front specific L-brackets, back plate brackets, 1 &1/2" foam gasket for back of bar, ABS honeycomb snap in inserts to retain the bolts and brackets, custom jumper harness with duesch connectors, custom precut plug and play wire harness to ground and switch panel wire, push pin zip ties for harness grill retention and all other stainless steel hardware, elevator bolts, locking nuts, and fender washers.
In fact, if we break down what the specific hardware costs me wholesale, the 4 brackets that are plasma cut and powdercoated are $40 a set (4 pieces... remember, if I ordered 10,000 at a time, they'd be cheaper...) then the stainless elevator bolts that are flat to secure the bar flat to the grill are $8 each.. there are 4... that's $32. Then you have the locking stainless nuts, and fender washers. Let's call that $2. And then you have the ABS honeycomb inserts (I print those.) let's call them $2. Then you have the wire harness and jumper harnesses. The auto grade duesch connectors and pins are about $4 per set. There are 3 of them used with the harnesses. That's $12, plus the wire. So if we add those items up individually, your at $88 that it costs me to make the kit plus time and design time. That's where the $150 for the kit portion comes from.
Both the grill and the insert are an abs plastic blend. Abs is resistant to warpage and cracking because it is semi flexible and very heat resistant. It will not crack the grill. In addition, the entire bar is a lightweight aluminum. In addition to weight, it also cools itself quickly. That's why it's so slim.
The abs foam gasket keeps the metal bar and brackets from touching the plastic grill so there are no marks should you ever remove it.
With the abs inserts, custom manufactured brackets, and lock nuts, the bar will not shift, move, shake, rub or damage anything.
This is the only kit designed with zero modification to your truck. No drilling, no cutting.
When I designed the install kit from the ground up.
There have been some questions on the "Edge" vs the "luminix" models. I designed the kit on the Luminix. However, if the curve is the same and the mounting points on the Edge are the same, it should also work.
The main difference I see in the "edge" is that it has I believe a 6 degree angle of light, vs 15 degrees. That means it is more of a "spot" light vs a "spot/flood" the luminix puts out 15,600 lumens and has a 3 year warranty. I believe the edge does as well. So the main difference I see is the angle. But again, I will be getting some edge bars in too and as long as they fit the same, I will add that kit as well.
So, all that said, what I will do is make a special coupon code for my parts site where you can go and buy the full kit and whoever uses the code can get an additional $100 off. This is for you raptor forum guys! Lol
Let's use code "raptorforum100" but it may be an hour or two until it is live.
The parts site is
Specialtyperformanceparts.com
My youtube channel where you can see a video demo of the kit and the install video (which I have much simplified and will ultimately repost soon)
Is youtube.com/jtrischler
I only have about 8 mount kits left until my next batch comes in in around 30 days, so supplies are limited if you want one. I'd encourage you to do it soon. Also, mark that parts site. I am getting ready to launch a bunch of cool stuff and there will be some really cool stuff coming out. Ground breaking!
Feel free to contact me at jtrischler@roushvehicles.net with any questions!
Not sure if I missed it, but is 30A correct on this bar? I see .75 per LED * 39 LEDS per 40" bar.
Please let us know when you get a chance to test and compare the edge model (and your other stuff too).
GT2344
South Texas
Just ordered mine from John on his website last week. He answered my emails and even gave me a call back. The guys at the shop I had it installed at couldn't believe how rock solid the mounts were. They've done nothing but behind the grill lights and Rigid cubes in the bumper on new Raptors. They were really impressed with this mounting system that John developed. They posted pics and within a couple of hour they had people calling their shop asking for this light and mount.
If I can figure out how to upload pics to this thing from my iPad, I will. You know what it looks like mounted, but everyone has been asking the "throw". All i know is that it is effing bright.
Thanks John for the fast order processing and delivery.
GT2344
South Texas
And one of the "throw"
These pics don't do the Putco Luminix curved 40" justice.
It looks like daylight. World of difference.
4x4TruckLEDs.com
So I wanted to chime in as I've sold a few of these to some guys on another forum. They were not bad products, but expensive for the amount of light they throw. What is great is what everybody sees, it's a very slim bar that kind of FITS in that little spot between the bottom of the bumper and the grille. But don't forget it's a single row LED bar using your traditional LED bulbs.
So it'll do a good job lighting up the road HOWEVER there are better options out there if you want MORE light (but none that I've found that are AS SLIM, Baja comes close but they still have a thicker light).
It's a nice slim bar that fits really nice above the bumper and curves nice to follow the contours... again I've had mixed reviews on it. Nothing bad where people said "THIS IS JUNK" more like "i was expecting more light" but for the most part the customers of mine who have bought this ARE happy with the purchase, because they bought it for a reason. They DID NOT want a HUGE light bar and wanted something that blended in nicely.
Hopefully that helps anybody on the fence about this. If you want a light bar that blends in and almost DISAPPEARS it's a great bar. IF you want a LOT of usable light, there are better options.
Either way if anybody wants a price on the Putco (or any other products) shoot me a PM.
97,027
60,955
penn_2
