Lower Grill options
ChevyChad
I didnt want to have to take the top main grille off either to relocate my ACC so i put it in the midddle of my fab fours bumper and then fabbed up a grille insert to go in front of it. Works great!
H
heffneil
You put the louvers back in after its moved? I thought you keep them out?
ChevyChad - you own a ford?! - Anyway where is that on your bumper I can't really tell?
Nick@Apollo-Optics
Correct. The ACC module is installed between the outer grille and the inner portion where the louvers are located.
H
heffneil
Oh so not behind the louvers. Thats interesting!
I think I should just change the bumper! I don't want to mess with the intercooler?! ADD is where its at for replacement bumpers right?
Nick@Apollo-Optics
That is our number one selling brand!
Here are the bumpers that will not require you to add an intercooler:
Stealth Fighter
HoneyBadger
Stealth R
Venom R
You can view all of them in full detail on our site, with installation instructions for each: https://www.apollo-optics.com/collections/2017-2018-ford-raptor-addictive-desert-designs-bumpers
We can also work with you directly to put a package together that fits your exact needs and budget. Let me know if we can help!
ChevyChad
LOL yea, I'm a chevy guy, but Im also a raptor guy. A bit of conflict of interests I know..
I put my ACC module right in the middle of my bumper. The location was originally for a light bar, which I had at one point, but I removed it to put the ACC there because I use that feature way more often than what I used the 20" light bar. I still have 6 other pod lights on the outer areas of the bumper. I may add a windshield bar in the future if I feel it necessary. But this was the best option to not have to go thru the crazy upper grille removal for the conventional ACC relocation method.
Here is a better pic where you can see it. This is before I painted the end brackets on the lower grille.
K1llD4shN1n3
Colorado
Really? The directions I saw looked lengthy and like a real PITA to do it? How long did it take you?
Also did you dump the louvers? I thought the active louvers were worth keeping for highway driving,. I kinda hate removing them? Seems like undermining ford....
The grill is surprisingly easy to take off and the louvre aren’t too bad to remove - I left a couple off near the top where the sensor is and it hasn’t seemed to make a mpg difference.
The hardest part was getting the plug wire to reach up through the bottom hole you have to drill.
Used this type of bit to drill bottom hole and it was easy. https://www.amazon.com/dp/B0169OLWTS/?tag=fordraptorforum-20
