Swaddict
I was looking at the RPG lower control arms, since they work with factory coil overs, any other brands to consider? Pros and cons? Not looking to go mid travel, these looked like a good starting point.
khc require aftermarket coilover and sway bar relocation.
theres no reason to replace the oem ones, unless you go all the way.
I have the KHC Standard travel with secondary, bumpstops and swaybar relocation
Hi, it feels very balanced to me. I do not fully utilize my shocks. I am very controlled over bumpy roads, potholes etc. Its a upgrade for sure, there will probably be some guys that beat their trucks that will give you more info.Can you give us a review of how it performs vs a stock truck. Also a little more information, Shocks and bumpstops you are using. Also your rear suspension setup and how balanced the front and rear are? Thanks
