Low Pressure Tire indicator - ON - !
GabAlmighty
Vancouver BC
Just because you picked up the truck at 36psi doesn't make it right, how many times in the past have dealerships been wrong?
Maybe bump em up to 40psi and drive on em for a bit and see what happens?
Now i'm curious as to what my tires are set at.. haven't actually checked em since I bought the truck and haven't aired down yet.
Fergusf16
Brimfield Ohio
I just had the same thing happen. It is fridged cold outside too. I did the reset procedure which is to turn the key off and then on and hitting the hazard light button 3 times and it gives me the message Train Left Front Tire. That sensor doesn't appear to be synced....
GTC-NOVA
GTC-NOVA
Well...temperatures climbed to above 30 degrees today in NOVA and the indicator went off. Left tires at 38PSI. Not sure if I would consider pumping them up to 40 or above.
Thank you all for the diverse feedback!
MTF
Celebration, Florida
Well, like I stated in the other two threads, 44 psi. is on the tire and on the door tag.
But I don't run that high myself, but I drive too hard on the streets to afford to go lower than 40 psi. in the front.
Also having to parallel park around NYC, 38 psi in the front makes it kind of hard to turn the front tires if you can't roll a little.
If the light went off then your tire gauge is off by a pound or more.
The TPMS module is set to 40 psi. no way around that unless you get a Tuner.
Now having said that, you can remove 1 LB per drive cycle to get down to 36 psi without the light popping on.
GTC-NOVA
GTC-NOVA
Must be a bitch to drive a Raptor in NYC, I would just close my eyes and let the others avoid me. And parking...? Look for sports cars - A Raptor sits so nicely on top of one. At least this is what I would do if owning a Raptor in NYC...:hitit:
MTF
LOL, yeah believe or not I have bumper and trailer hitch scrapes from the low lifes with crap cars trying to park.
I have even pick out plastic grill parts out of the trailer hitch. Idiots I tell you!!!
GTC-NOVA
GTC-NOVA
Yes - baby!
If mortals do not understand what kind of vehicle this is and do not pay respect or open their eyes - then by all means...make them pay! Hail to you my friend!
