Lost wipers, head lights stay on more??
FAMARO
Katy, Texas
LV, what year is your truck? I think there is a TSB on certain years concerning the 3rd brake light. Either way, I would suggest going back to all stock BEFROE you take it to the dealer. If not, they may want to blame it on your aftermarket stuff and then not cover anything under warranty.
Raptor Retrofit
HID Specialist
NY
3rd brake light also has a lota green build up around LEDs
Dude, without a doubt its your 3rd brake light. It was a bid problem with the 2010's. happened to me and many others, same thing your describing, had mine replaced and haven't had a problem since.
Call your dealership, there was a TSB for it. Ill see if I can find it.
Hill Decent Control Fault. SSM 21317
Oasis special service message number: 21317
message title: 2010 svt raptor - hill decent control fault and dtc c116a
applicable vehicles :
2010 truck : 00029 f-series ld
oasis message :
Some 2010 f-150 svt raptor vehicles may exhibit hill decent control fault with
abs dtc c116a. On vehicles built before 2/26/2010 only, inspect the high mounted
stop lamp for evidence of water intrusion. Refer to wsm section 417-01 for
replacement details part number al3z-13200-a. Torque screws to 1.5 nm / 13
lb-in. No water intrusion follow wsm section 206-09, pin point test i. Note: It
is normal for the brake pressure (brakpres) pid to occasionally spike high due
to test pulse sent to the pressure sensor by the abs module. In addition, brake
pressure signals as low as -225 psi without brake apply should also be
considered normal. .
Applicable symptom codes :
200000 electrical
206000 electrical warning indicators
300000 chassis
301000 chassis service brake system
Lance Vincent
Lance Vincent
Knoxville,TN
Its a 2011 was early off the line.
Thanks Guys for info looks like im going to the dealer/stealer/
Hey question if there is a TSB out and im over on miles will they still fix under warranty?
Im at about 42,000 + miles
Humvee21
They should still fix it.
FAMARO
Katy, Texas
TSB and SSM are only job aides. Only recalls are most times covered past the manufactures warranty limits.
Raptor Retrofit
HID Specialist
NY
Also noticed today i lost the switches on steering wheel
You may have something else going on along with the 3rd, I never heard about so many different issues. Make sure you tune it back to stock before bringing it in so they cant put any blame on you.
Lance Vincent
Lance Vincent
Knoxville,TN
Back to stock now .
Dealer in next week.
List of things that quit.
signals
high beams
wipers
headlights stay on with switch in off pos
steering wheel controls
hill desent light
advance traction light
Raptor Retrofit
HID Specialist
NY
Another thing that was happening a lot was brake lights sticking on.
Lance Vincent
Lance Vincent
Knoxville,TN
Update
Truck is at dealer.
They called and told me this.
Steering colum module Part $209.63
Labor $331.00
110v outlet Part $13.63
Labor $112.00
3rd Brake light Part $392.50 hahahahaha realy
Labor $50.50
1109.26
Plus tax
They also said that it may or may not fix all the problems!?! ???
I told them to just fix the Steering colum module.
I will prob just buy a recon 3rd brake light install my self
and say to hell with the 110v outlet.
They had no idea what started the faults.
