P1548 is probably a good place to start - clean/replace the air filter. The ECU is comparing barometric pressure to measured and modeled pressures along the intake tract. If the differences are significant, it'll infer that the air filter is clogged and providing restriction to the engine. It could also be worthwhile to check the charge pipes and BOV for leaking under boost - based on our investigation of how the code is triggered, I could see how a small post-turbo boost leak could mimic the fault conditions (small enough leak that the turbos can work harder to compensate for the underboost, avoiding an underboost code, but enough of a measured or modeled pressure differential that this code is thrown). The boost control system will attempt to correct for the restriction by running the turbos harder, which can create excess exhaust manifold pressure and contribute to misfiring.
