Looking to do reverse light bulb to LED swap.
Rock-eater
Corrales
I want to swap the reverse light bulbs with some super bright LED replacement bulbs. Anyone done this? What LEDs did you get?
Also anyone swap out the incandescent bulbs in the 3rd brake light/bed light with LEDs.
Thanks
fjcoop
Thanks
I have the XP50's from diode dynamics for 6 months now, crazy bright. They were great to work with when I ordered the wrong set the first time. The link is noted below.
Diode Dynamics
raptor_qatar
Doha, Qatar
How about installation? Is it a simple DIY? Because I really don't want condensation inside the lights
Sent from my SM-G925F using Tapatalk
Yukon Joe
Trafford, PA
Very simple. Remove the rear tail light. Remove reverse bulb holder, remove original light bulb, install new LED bulb. Resemble.
Yukon Joe :baby: :baby:
just Mike
Colorado
I just got the XP50s from Diode Dynamics. Fast shipping, super easy swap, and they are pretty bright. Not like adding dually's for reverse or anything, but way better than stock.
justuspost
Portland OR
I will point out that you can put the bulb in backwards. Then it will flicker. You then have to remove it and turn it around. Kind of a pain. Best to check before reassembly.
Sent from my XT1575 using Tapatalk
