Looking for Corsa Extreme review
Stang
Can't really tell from the video but is the cold start loud enough to **** off your neighbors at 6am? Trying to avoid that.
Sent from my SCH-I545 using Tapatalk
Deletedone
nunya, ca
I was worried about the same thing, but it's not that loud. Just a low rumble. There's also a "quiet start" option in your vehicle settings for remote start if it's too loud.
Stang
Cool, thanks. Learn something new everyday on this truck.
Goofball
So I will be the ******* and just ask... Can we just buy the muffler? only because I want to do something different to the pipes as I don't like the stock location. Thoughts?
FullAuto
So, I got about 350 miles on it so far. It's definitely gotten "Throatier" as it broke in. It was a nice day out today so the windows were down. Definitely gets loud when you get on it but is really near stock when not hitting the gas. If you are just tapping the gas a little the volume is slightly louder than stock. Sort of has a split personality. Cold starting it does burp fairly loud when it initially starts (tried it on quite mode and it still seemed loud at the start) but the idle is not bad at all. Slightly higher than stock but nowhere near obnoxious.
BobCajun
Ashburn, VA
Installed mine yesterday and so far I really like the sound. This is my first modified exhaust ever and it was a big sigh of relief after driving it 60 miles. Was really worried I would not like the increase sound levels. The only on going concern I am going to have is the cold start...neighbors are close and I use a parking garage at work. I'll have to try the quiet remote start like you mentioned.
Corsa did send the Sport instructions, guess they haven't taken the time to update for Extreme. Easy enough to figure out that you swap the straight pipe for stock resonator though.
Love the Black Tips!
VAFordGuy
Alexandria, VA
Did mine Saturday and love it! Sounds great just as others have said. I did change the exit though. I installed it normal and decided I did not like the look of the Corsa exit. So I cut some of the resonator delete pipe in order to hang the Corsa muffler back about 4-5" This gave me enough room to make a Y pipe to accommodate the stock exit. It did not change the sound at all and no drone.
Removed some of the resonator delete pipe and moved the hanger bracket back. (Ford already has holes there so it was fairly easy)
Fabricated a Y pipe to fit the Corsa single exit to the Ford stock dual exit.
Members online
No members online now.
95,320
58,843
brucebarson
Latest posts
