aloha_rotpar
Looking for a reference picture of a 2013 OBDII port. previous owner cut/modified OBD II port. truck will start/stop/drive/etc normally, I'm needing to rewire to pass Oregon Emissions.
I tried to get the colors and positions but they kept coming out crappy.
How is Fords obd2 be different than other makes? From what i understood the systems were standard?thanks for getting these. I could not get a ford pigtail local, so I got a universal OBDII pigtail and soldered in leads that matched the pin positions.
unfortunately, once complete, still not getting power to pin 16. tested pin #4 for ground with volt/ohmeter and that looks to be correct.
next step is to pull/check/replace fuse #24 which is listed as a 15A minifuse (datalink connector/steering wheel control module)
will advise more tomorrow.
