I replaced my OEM tires with E rated with virtually no difference in ride quality at 38 PSI. They are tougher off-road, and more flat-resistant.This is why I won’t run E load rated tires on anything but a diesel.
Wow. I had a set of stock size E Continentals on mine for a while. The ride was absolutely horrible, even aired down to 25 psi.I replaced my OEM tires with E rated with virtually no difference in ride quality at 38 PSI. They are tougher off-road, and more flat-resistant.
I switched to the E rated KO2 8k miles ago. No noticeable difference other than they seem to run a little stiff when cold but that goes away after driving for a few minutes. No issues at all now that the weather is warm. I run 38psi. They also performed great off-road at Durhamtown in GA. You may have a hard time finding the C rated ones. They were unavailable through Costco for some time. I ended up going to NTB. I also filed a claim with Michelin/BF Goodrich since mine wore out at 22k. They gave me 25% off a new set.
Those were continentals, not Yokohama Geolander G003 MTs. Continentals on a Raptor, really? LOLWow. I had a set of stock size E Continentals on mine for a while. The ride was absolutely horrible, even aired down to 25 psi.
Gonna have to call BS on you running an E tire at 38 and not noticing a difference in ride, sorry.
Actually this is wrong. All large rock crawling tires are C range as the sidewall is more flexible and grips the rocks better. A softer side wall also enlarges the contact patch. I do a lot of rock crawling in Moab with my Jeep that has 40" tires, KMs C range. I have only had one issue with a sidewall, and the new KO2s have a much stronger sidewall than my old KMs. Ford worked for a couple of years with BFG to develop that tire. In 35s that is the only one that has a C range. It gives a better ride, and is better off road. Get them to change it back for the correct one. They should have known that Raptors take that special tire.Plus if you hit the dirt and hit any rocks you will wish you had 10ply.
It might be easier to break down the tire and swap the TPMS rather than to have to program the additional sensor on each rotation. On second thought, a full set of sensors is only $60 on Amazon. Verify the part number works on the Raptor, this is what I got searching for Ford TPMS.
https://www.amazon.com/dp/B0034ROE76/?tag=fordraptorforum-20
Sorry, I meant to say BFG tires, not other brands. You are correct. I happen to like BFG tires, they have served me well, and don’t know a lot about other brands.Toyo makes some 315/70 tires in C load range, ATIII, MT, and RT. Others that would work on a stock truck and are C load are the 35x12.5R17 Goodyear MT/R and the 35x11.5R17 Nitto Trail Grappler.
https://www.discounttire.com/buy-tires/toyo-tire-open-country-a-t-iii/p/88598
https://www.toyotires.com/tire-finder/size/315-70-r17/
https://www.goodyear.com/en-US/tires/wrangler-mtr-kevlar/sizes-specs
https://www.nittotire.com/light-truck-tires/trail-grappler-mud-terrain-light-truck-tire/
