Limp Mode
ellismcdan09
South Carolina
I drive a 2014 6.2 and its been goin into limp mode…. been to the dealership now 4x already regrading this issue…i really believe its the PCM because , they already replace a cable that was connected to the transmission, it shifts fine until goin into limp mode, already had transmission work done to it, flush and everything, they just recently dropped the pan and check for metal but did not find any metal to raise a red flag…… so I’m just seeing if anyone else has had this problem with there truck and has any suggestions…thanks
FordTechOne
Detroit
Limp mode can be caused by a lot of things. Do you have the DTCs it’s setting?
CoronaRaptor
CANADA
Mine was going into limp mode once I hit 105mph. I was told it was a factory safety setting by Ford.
The factory governor is set around 100 mph, but with yours being whipple tuned it could be overriden and you might have another issue.
