They all stayed on. Everything looks exactly the same.
Please keep me in the loop once you get a solution from the dealer. So far based on what I've seen/personally experienced, I'd group them into two issues ( if it isn't a plug or short)
-ABS fault
-Forward Collision Warning fault
-Park Aid fault
-Steering Assist fault
= ABS sensor short / cut wire
-Powertrain Malfunction/Reduced Power fault
-U0401 Invalid Data Received(ECM)
= Big change to environmental conditions ( altitude, octane, intake leak) Realistically the U0401 is the MAF and TPS showing values that do not match based on other readings.
-Restraint Indicator Lamp fault
makes me think it is an electrical short, loose plug, etc because it makes ZERO sense with the other two groups of messages.
I'd be interested to understand what IDS says when the truck is scanned vs what a standard obdII reader pulls.
