Lightweight 17 Inch Wheel Options
everestwc
Maryland
Any weight numbers on the 17” Black Rhino Stadium? Price? Can Pacific mount and balance tires and ship all together?
Pacific Wheel
Pacific Wheel
Reno, NV
haven’t updated this in a while but the stadium is 27lbs. We can do a package. Pm me what setup you want to do.
gto19
I think my my method 316 wheels are around 26 pounds . Thanks pacific wheel for them .
Question about these and offset. My 19 is stock right now and if I went with these in 18 offset would I still need to level my truck so it doesn’t rub? My 17 I had to level it to run RRW 0 offset.
I’m not Justin and didn’t stay at a Holiday Inn Express last night but I asked a very similar question;
2017, no suspension mods, will the trail lites rub with stock tires/ KO2 C range. He said no rubbing with the +18 offset
I have a follow up on this topic set for later in the year as I’m nearing the need for new tires.
Braaaaptor
Starbucks Enthusiast
The drive-thru
I run 17x9 Enkei's w/ +12 offset on my 2020 and don't have any issues with rubbing and didn't need to trim w/ stock KO2's.
Jumping it would probably be a little bit of a different story, after seeing how much the wheels tuck at full compression at Raptor Assault, IMO it'd be safest to upgrade springs before really maxing it out. I'll defer to the experts on that last point though.
Pacific Wheel
Pacific Wheel
Reno, NV
This is correct. +18 will be good for stock.
GordoJay
Colorado
Jumping it would probably be a little bit of a different story, after seeing how much the wheels tuck at full compression at Raptor Assault...
Unless they jumped a lot higher than we did, that's not full compression. We didn't hit the bump stops, it was like landing on a pile of pillows.
