GEN 2 Lighting Recommendations
OffroadAlliance.com
Boston, MA
Does anyone know if the light bar behind the grill would interfere with a Cobb intercooler?
Unless you're doing some kind of custom mounting, there aren't any light bar kits that are compatible with the larger front mount intercoolers like the Cobb, Full Race, ADD, SVC, etc.
desertfox73
Nashville, TN
Negative. FMIC's take up too much room. I've seen guys MAKE it work, but it's not going to install as intended and will require you do get creative.
Thanks - appreciate the help.
4x4TruckLEDs.com
Pompsy
Pompsy
South Florida
I know there’s a big push for Baja Designs, but I went a little different route.
Aux Switch #1
Two Pair of Rough Country 3” Wide Angle OSRAM LED Lights
One Pair of Rough Country 2” Square Cree LED Lights
Lights Mounted with the Rough Country Light Bracket for the Raptor
Aux Switch #2 runs the Rough Country 12” Cree LED Light Bar (Dual Row) in the middle of the bumper
Aux Switch #3 runs the Rough Country 30” LED Hidden Grill Light Bar
View attachment 151206 View attachment 151207
That's a great setup! I definitely see why there is cult following for BD. I myself decided on the Rigid Radiance Scene (mostly for the amber back light to match the OEM amber's). Is the lower grille light bar mounted on the inside on yours?
