LED side vent lighting
bigred1097
Westfield, MA
Thanks for the info. I assume the vents remove from the top, and there's no opening on the bottom side to pop them through? Never had the hood insulation off before.
This is definitely a spring time mod, too cold here to do it now, the plastic gets hard and makes popping clips out much harder.
Yes they do remove threw the top there is an opening but it too small to work threw I would either wait till spring or find a heated garage
Tiberius
Awesome mod guys. Was thinking about buying premade light with SVT but I like this better. Any pics from further away of the hood?
jdombrowski1077
jdombrowski1077
Norwalk, CT
Made a little progress. Installed the blue puddle lights from AMB Lighting tonight. The other lights may not get installed till closer to thanksgiving. I am scheduled to do the hood vents blue, Running board ground lights blue, and bed will be white with a remote switch in the bed area. I am also throwing around putting led strips somewhere in the rear to provide addition reverse lighting. Will keep you posted and do a full write up when done.
Kerr477
Hawaii
TheDoubleAA
Kemah Texas
you can do the breathing side vent lights... You can also have it set up in the vents and in the hood as well.
TheDoubleAA.com
95,793
59,476
egermann
