LED light bar behind the grill
NJSP117
New Jersey
Hey guys, if you're looking for a bolt-in solution, we're got our pre-order list up and running. This kit allows you to fit a 30" Baja Designs S8 light bar behind your grille.
Pricing for the kits should be available soon. If you have questions or would like to get on the pre-order list, please feel free to shoot me a PM.
Would a 30" Rigid work as well? I have a 30" and a 40" that I took off of my Gen 1.
Can you add me to the preorder list?
Nick@Apollo-Optics
I don't think so. Even the OnX6 light bar is too big to fit inside the 30" bracket location.
Which Rigid do you have? I imagine the only light that might fit would be the SR-Series. If it's the E-Series, it will not fit without making modifications to the grille or shutters.
---------- Post added at 06:58 AM ---------- Previous post was at 06:58 AM ----------
Same here!
Sending you a PM now!
Huck
Chicago Sw Burbs
So did some research...
The baja designs S8 - 3.0" deep
VisionX - PrimeXmitter - 3.3" deep
Whelen continuum - 3.04" deep
So if the S8 fits between the girll and the louvers. the whelen should for sure, and its a guess about the VisionX.
I didnt look at rigid because it didnt have them on my gen1
RaceDeck
Do you have any pictures of how you are mounting this in behing the grill ?
Here's a shot of what the light looks like installed:
Nick@Apollo-Optics
Hey there. Thanks for your question. We don't have pictures yet, but I have confirmed with Baja Designs that the mounting kits will be bolt-in. No drilling required.
hewster
Virginia
There are active shutters on both the main rad and intercooler.
I am in the process if test fitting lights myself
Copp5
Mounted 2 12" rough country lights behind the grille last night.. I'm going to call it the header panel where the shutters are. that structure and the grille bolt together, separated them took out a couple of the shutters and fabed up a couple of very simple brackets and mounted the light bars to the headerpanel and then bolted that and the grille back together.. didn't grab any pictures during the process (too focused on how we were gonna do this hahaha) but I'll grab some of the finished.. the black rough country lights looks good behind the grille!
