Alligator
Hope to see them released soon
It would hurt bad. I was demonstrating them for my brother.. Standing 30 feet away and you could feel your shirt vibrate when they went off.It would be a cruel prank for the horn to go off while underneath the truck. You’d fill your pants. Hahaha
It is not, although it has never died on me. It's a cheap Motorola phone that I have set up.
Edit:. I may have misunderstood your question- the hotspot is setup (Tasker) so that if the truck is not in my garage, the phone's hotspot turns on and remains on even when the truck is off/parked. It is plugged into USB port in center console and charges when the truck is running. Primary use for hotspot is internet connection for dash camera while parked. WiFi switch is connected and horns are available for remote honk even while parked/off.
Sent from my SM-G965U using Tapatalk
Tasker is not terribly intuitive, but the way I have mine setup is straight forward. Only issue is that some phones will not let Tasker control the wifi hotspot, in which case you would need to root and it becomes more involved. Motorola e5 Play is what I'm using and Tasker has access to hotspot control without root.I need to look into something like this, I have an old phone I could use for it, just need build/obtain the tasker part.
Snowed yesterday here in Denver, drove for the first time with the horns installed in the snow/crud: Yes they do collect crap from the road. The rear horn had a good amount of snow packed in and around it. I called kleinn to ask this question- guy on the phone said that they are meant to take debris. Stainless diaphram inside the base. He said that if they sound off, there is likely debris in there and to unscrew the trumpets and just clean them out. Most of the time, honking them should clear it out.@SlickMachine Are those horns pointed so the opening is facing the front of the truck? If so, has Kleinn mentioned anything regarding mud, other road debris getting in there and what the impact would be? Did you happen to post a straight on side view of all the hardware you added? I’m trying to get a better idea of how visible everything is.
Thanks for the post!
I'm thinking some stainless mesh to go over the trumpets.Personally, I would just make a custom small sheet metal guard to protect them from debris, just mount a shield plate far enough in front of the horns that it wouldn't dampen the sound and angle it to block flying debris. same with the air tank on the other side, just a bit of extra protection from flying rocks
