Kicker Sub upgrade
htsai14752
SoCal
So you still have the oem amp plus another amp for the new sub? The new sub was direct drop in?
dmb359
Minneapolis
Good easy option that doesnt lose floor space, I like it. May have to consider this. Thanks for posting the pics.
traxem
Zoom into the last pic and you can see the 4 wires going to oem sub that I hooked up to the input side of the amp.
So the input to the Kenwood amp is the subwoofer output from the B&O amp? Is that correct? If so, is there a hi-lo converter somewhere?
If you did daisy-chain two amps, how did you compensate for the bass roll off from the B&O amp? (Because the factory system reduces bass level when you crank up the volume to protect the factory speakers).
I’m interested to try this but have those thoughts.
