GEN 2 KHC Torque Arm, anyone running it?
Wfo
Syracuse
They are showing it with and without. All I am asking is what leaf springs are on the one with it installed ?
It is mounted with deavers installed. It’s a pretty sweet design with no interference with ground clearance and integrated skid plate.
06z
So Cal
Thank you. I like the skid plate.
khcdave
South Brunswick NJ
Curious how much deaver +3 help with axle wrap? Love to see a vid depicting deavers alone.
Next shop install we do I will get some video with aftermarket springs alone. The video with the torque arm is my truck with Deaver’s. Torque arm with stock springs has the same affects. Aftermarket springs make a big difference compared to stock springs for sure. But you still get natural spring wrap based on torque output.
khcdave
South Brunswick NJ
will this work with long travle rear? 18+ inches of travel?
Dan Dunn in michigan tested it for me with his SVC mid travel set up in front and long travel in rear with 18 travel shocks. No issues with full down travel. It does have some natural binding in the lower part of the travel range but the mounting bushings at the axle end absorb it.
2 more days to get in on the torque arm group buy:
#39
ljn21
Tega Cay, SC
Can the torque arm be used when the rear is lifted higher than stock height like with deavers or icon springs? Can’t visualize in my head the attachment points relative to lifting the rear higher. The attachment point on the rear frame would be affected?
OffroadAlliance.com
Boston, MA
Yes it can. No issues with OEM springs or aftermarket like Deaver or Icon.
