- Joined
- Dec 16, 2016
- Posts
- 18,256
- Reaction score
- 28,723
Got it. I’ll check it out.
Also got in contact with KHC and they said it was from the arm not being properly adjusted. I'm not sure what they mean by that since the instructions literally just say adjust the rear until you can get the bolts in.. So I'm waiting on a response from them on what they say.
Is there even a way to adjust the "length of pull" on the slip yoke?
if your theory is correct, what about something like a cv boot?
If I were a betting man I would say the shaft got something around it when it was fully extended and when it went to compress back down the bushing couldn't slide on the shaft so it was shoved back down into the arm. I don't know what could have gotten on the slip-yoke shaft to make it so sticky the bushing wouldn't slide but that's weird.
Also TBF to KHC even though I don't have a ton miles in the dirt with it, when I do go I'm not friendly with the truck lol. All things considering 10K miles before a failure doesn't seem too bad for an aftermarket part being put to use.
The way that arm is worn out at the mouth you will never get another seal to fit. You can fill that space but when the yoke rocks up and down it will just tear out what ever fill material you put in there. Unless, you could take it off and weld up that lower worn spot then turn it down on a lathe. We used to do this to prop shafts and axle shafts that would get seal groves in them. We would weld up the grove and then turn it down on a lathe. YOu cans o the same with the yoke, either over-bore it and go with a thicker seal or weld it up and turn it back down.
Just remember to keep the grease zerk exposed --and use it often![]()
I didn't drop the drive shaft so the only way to get the arm in there is with the back end fully extended
So Basically what you have to do is get the arm into the slip joint and drop the truck on the ground.
NegativeHoustonNew York. You just have to possess grit and determination. I installed this in my driveway. It was a multi-pint affair for sure, but installed over a weekend, in the driveway, no lift, using common garage tools, and several pints of home brew. ... IPA if I recall correctly.
I don’t know what led you to this conclusion, but as I stated, I got this thing in without dropping the drive shaft or on a lift. So, hopefully that inoculates Lucille against this kind of wear.
I was going to drop the d/s, but at some point in the process I looked and said to myself : “F this, I can get this installed without dropping the driveshaft.”
Now, I know it took me longer, but how much longer is complicated by not using a lift and not dropping the d/s. I started early afternoon on a Friday getting the brake lines adjusted and cradles in place. Saturday I hit up the front end, got things secured in the rear. I even called them once or twice with questions.
I buttoned everything up Sunday AM, double checked clearances, connections, bolts, etc. Took it for a shake down run, checked again, then took it out in 2H and did some teenage hooligan $hit to try and get some wheel hop. I didn’t.
I crawled underneath Lucille last night and inspected, nothing like your front end at all and the explanation seems plausible to me. Everything is looking good on mine.
Good luck with the repair and please keep us posted.
And Merry Christmas. I know it sucks to have to repair a mod, but look at it this way, you’ll get to reinstall the mod and that is almost as satisfying ;-)
