Just got a raptor
Agreed, Ford ESP is excellent. I think Omar may have been referring to the aftermarket warranties that some dealers sell, which are generally terrible.
I’ve have vehicles with extended factory warranties, aftermarket extended and vehicles without extended warranties. Of the new 4 wheel vehicles I’ve purchased I’ve used the factory warranty pretty heavily, including a successful lemon lawsuit on one of them. After the 3/36/etc I’ve used both aftermarket and extended warranties 4 times. Once was the Ford ESP on my Lightning, the AC compressor went about 2007-2008(?) the part was 900 bucks from the stealership, I paid the $50 deductible and moved on with life. The aftermarket warranty was a dog fight to get coverage, then get the repair itself fully paid and was way too much drama.
If you are calculating a need for a reliable daily driver, and you’re not planning on heavy modifications, the Ford ESP can cover you out to something like 8 years 125k miles - I think that was the max when I looked. If you got an 802A with moon roof, there’s a lot of things that can go wrong, but they’re also statistically pretty good.
If you suffer one hard part failure after 60k, the warranty will probably pay for itself.
OTOH, if you’re going to mod the truck and do Raptor things with your Raptor, set some money aside in the bank for repairs and enjoy life. Just because I had good experience with the Ford ESP and not so much the Allstate plan, doesn’t mean you’ll even need it or that you should get one. Make the decision that’s right for you.
84 Sheepdog
Dallas, TX
I thought the Ford ESP plans were only available for purchase up to 41k miles. Doesn't this truck have 44k miles? I might be mistaken but that was my understanding when talking to Flood.
Raptorjv
Raptorjv
Bayside ny
All my local Ford dealers here and Ford esp told me that I have 5 years or 60k miles from when the truck was purchased to extended the warranty. I have 1 year left roughly on powertrain.
Joeeyyy
Arizona
Flood Ford ESP website confirms 84 Sheepdog's post
Drgonzo3000
North Carolina
Got denied coverage from flood ford today on the Raptor I just bought. It's under the 41k, but according to them it's too old, over 41 months.
Oldfart
Dealer extended warranties are a waste of money. They don't cover much and most of the parts that need replacement are wear and tear items that are not covered in any Warranty.
I agree, they don't cover anything, what a waste of money. Of course, that is, except those one or two minor things Ford ESP does cover, like,
Engine Components Covered
  • Flywheel Ring Gear
  • Fuel Tank and Lines
  • Gas Fuel Injectors and Fuel Lines
  • Harmonic Balancer and Bolt
  • Manifold (Exhaust and Intake)
  • Manifold and Bolts
  • Oil Pan
  • Oil Pump
  • PCM Module
  • Radiator
  • Radiator Fan (Clutch or Motor)
  • Seals and Gaskets
  • Thermostat
  • Thermostat Housing
  • Timing Chain Cover
  • Timing Chain (Gears or Belt)
  • Turbocharger/Supercharger Unit (Factory Installed)
  • Valve Covers
  • Water Pump
Transmission Components Covered
  • All Internal Parts
  • Governor Assembly
  • Kickdown Linkage
  • Release Hubs and Bearings
  • Seals and Gaskets
  • Torque Converter
  • Transfer Case (Including All Internal Parts)
  • Transmission Case
  • Transmission Linkage
  • Transmission Module (External)
  • Transmission Mounts
  • Vacuum Module
Rear-Wheel Drive Components Covered
  • Axle Shafts
  • Bearings (Front and Rear)
  • Drive Axle Housing (And Front Axle Housing for 4x4) Including All Internal Parts
  • Driveshaft
  • Retainers
  • Seals and Gaskets
  • Universal and Constant Velocity Joints
Front-Wheel Drive Components Covered
  • Axle Shafts
  • Final Drive Housing (And Rear Axle Housing for AWD) Including All Internal Parts
  • Hubs, Automatic Front Locking (Four-Wheel Drive)
  • Locking Rings (Four Wheel Drive)
  • Seals and Gaskets
Steering Components Covered
  • Column Lock (Tilt Wheel)
  • Control Valve
  • Cooler and Lines
  • Idler Arm
  • Linkages and Couplings
  • Power Steering Pump
  • Pulley Assembly
  • Seals and Gaskets
  • Steering Gear Housing, Manual and Power (Including all Internal Parts)
Brakes Components Covered
  • Anti-lock Brake Module and Sensor
  • Backing Plates
  • Brake Booster (Power)
  • Calipers
  • Combination Valve
  • Lines and Fittings
  • Master Cylinder
  • Parking Brake Linkage and Cables
  • Retainers and Clips
  • Self-Adjusters
  • Shaft (Brake Pedal)
Front Suspension Components Covered
  • Ball Joints (Upper and Lower)
  • Control Arms (Upper and Lower)
  • Control Arm Shafts and Bushings
  • Kingpins and Bushings
  • MacPherson Struts
  • Spindle and Spindle Support Springs
  • Stabilizer Bar
  • Tie Rods
  • Load Leveler Suspension System
  • Roll Stability Control
Rear Suspension Components Covered
  • Linkage and Bushings
  • MacPherson Struts
  • Stabilizer Bar
  • Tie Rods
A/C and Heating Components Covered
  • A/C Accumulator
  • A/C Clutch
  • A/C Clutch Bearings
  • A/C Compressor
  • A/C Compressor Clutch Switch
  • A/C Compressor Head
  • A/C Compressor Seals
  • A/C Condenser
  • Automatic Temperature Control
  • Evaporator
  • Field Coil
  • Heater Blower Motor
  • Heater Control Assembly
  • Heater Core Assembly
Electrical Components Covered
  • Ignition Switch
  • Intelligent 4WD Systems
  • LED lighting or Lamp Assemblies-Interior or Exterior(Factory Installed) - coverage included only if the Lighting option is purchased
  • Mirrors (Electrical Only - Not Glass Damage or Breakage)
  • Power Running Boards
  • Radiator Fan Relay
  • Rear Window Power Sunshade
  • Speedometer/Odometer (Electrical and Mechanical)
  • Starter Motor
  • Starter Motor Solenoid
  • Switches (Manually Operated Electrical)
  • Temperature Gauge
  • Vista Roof
High Tech Components Covered
  • In-Dash Garmin(TM) Voice Activated Navigation System (Factory and Dealer Installed)
  • Instrument Cluster (Excluding Dash Pad)
  • Keyless Entry System (Excluding Door Handles)
  • Power Antenna
  • Power Door Locks and Retainer Clips (Excluding Door Handles)
  • Power Seat Motors
  • Power Window Motors/Regulators
  • Rain Sensing Wipers
  • Rear Console Refrigeration
  • Reverse Camera and/or Sensing System
  • Securicode
  • SecuriLock(TM) Passive Anti-Theft Ignition System
  • Sensor (Alcohol)
  • SOS Post Crash Alert System
  • Speed Control
  • Stationary Elevated Ride Control
  • SYNC
Emissions Components Covered
  • Air Control Valve
  • Air Idle Vacuum Valve
  • Air Supply Valve (Hose and Tube)
  • Air Check Valve Assembly
  • Barometric Pressure Sensor
  • ECC Relay Assembly
  • EGA Control Valve
  • EGA Pressure Sensor
  • EGA Regulator Assembly
  • EGA Valve Adapter
  • EVAP Vapor Storage Cannister
  • Idler Air Control Valve
  • Knock Sensor
  • PCV Hose Assembly
  • PCV Valve
  • PCV Vapor Filter
  • Temperature Sensor (Engine Coolant)
  • Vacuum Restrictor
  • VAF Sensor
Audio Components Covered
  • Antenna, Radio (Base Assembly)
  • Brackets
  • Cables and Wiring
  • Cellular Phone, Receiver, Handset, Speaker Assembly and Antenna (Factory Installed)
  • Controls (Rear Seat)
  • Radio (AM, AM/FM), Speakers, Cassette Player, Digital CD Player, Graphic Equalizer, Premium Sound Amplifier (Factory Installed)
  • Rear Entertainment System (Factory Installed)
Safety Components Covered
  • Airbag Module Assembly
  • Diagnostic Module Assembly (Airbag)
  • Door Ajar Warning Switch Assembly
  • Guides, Bezels, Brackets and Supports (Safety Belts/Shoulder Straps)
  • Head Restraint Retainers and Sleeves (Safety Belt)
  • Key, SecuriLock(TM) (Microchip Encoded Key)
  • Lock Cylinder (Door)
  • Lock Lever Assembly (Tailgate)
  • Lock Lever Retainers, Clips and Brackets
  • Module (Passive Restraint)
  • Safety Belt Buckle (Front and Rear)
  • Safety Belt Motor Drive Assembly
  • Safety Belt Restraint Carrier
  • Safety Belt Retractors
  • Safety Belt Track Assembly
  • Safety Belt Warning Chime Assembly
  • Sensors (Airbag)
Are you fu**ing kidding me?!
