Seems much less to sub and rear speakers. Don’t think I’m a fanJust did the change of the audio. The front stage you can tell it got a boost of sound. I couldn’t tell a difference in the woofer.
My suggestion is to just bite the bullet and replace the stock sub with a Kicker and add a small amp... I got the ACM 1.300 which has inbuilt LOC and Accubass for like $140 and the Kicker sub is around $100.
I just did it and couldn't be happier. I was close to going full Nav TV amp replacement etc. but the way it is has enough bass to shake the rearview mirror and the amp is at half gain.
I am going to try this mod once the sub is broken in though.
Thanks for posting. I have been following this thread on F150 but there has not been a lot of discussion.
https://www.f150forum.com/f30/2018-b-o-stereo-forscan-breakthrough-411268/index3/
I would like to know tooWhich Kicker sub did you get and did you fit it to the existing enclosure or purchase a new enclosure?
Hit me up when you visit the Cuse.I have a '19 with B&O. I used the stock sub enclosure, sealed the port and Dynamatted the hell out of it as I had a bunch lying around from doing the wife's jeep a few years ago. I used the Kicker 43cwrt81 wired in series which I purchased used from smurfslayer. A few months ago when I was purchasing it could be had new for under $100 but $150 seems to be the norm now. When Amazon gets stock back I expect it will be lower.
With the ACM 1.300 it seems to distort the sub at much more than half gain but there is plenty of thump. I wish I got the newer ACM which has remote control facility so I could crank it up when needed but I only paid $140 new for the old model which doesn't have the connector. Bass varies dramatically on Sirius XM channels, for example 80's on 8 and First wave have little bass. RTB radio has moderate and the Joint reggae channel is extreme. It would be good to be able to tweak from the driver's seat.
I also replaced the door speakers with Pioneer 5 way 6x9s which are about $60, put fastrings on and dynamited the doors. Tweeters, rears and centre channel are stock. Centre will probably be converted to be the speaker for my VHF.
Wfo, I sometimes get up to Syracuse to visit family. If I do I'd be happy to let you listen and have a fiddle.
