Just a warning for those tuning gen3s.
TwizzleStix
Commivirginia
Actually, the government or any entity literally spying on my activity through clandestine access to my property is patently illegal. If these goons don’t have my consent in writing, or have a valid(?) court order to tap into my vehicle device(s), then I’ll take it as a communist attack and respond accordingly.
WTX
The Permian Basin
While I agree with you. Correct me if I am wrong, but if you give Ford permission to log your trucks data via FordPass can the government file a court order to hand over that info? With the BS they are pulling now they could fine you for tampering with factory settings. Just like they are doing in the diesel world right now.
melvimbe
I thought I had read somewhere that Ford is also using a new encryption that will make it impossible, or at least very difficult to apply an aftermarket tune. That true?
Syberspace
Pittsburgh
This is what I a hearing as well... no 2021 F150 tunes yet from MPT or others (from my limited search), unless a piggyback is out there. MPT says untunable for now... assuming the raptor is the same, since most likely similar ECU.
coryatver
PA
well it uses cell signal. So cut the cell signal connection and it can't communicate. Good to go. Im sure the performance shops will have a easy fix.
