Jumping with bed cover
taquitos
Seattle
Would a pair of those bed support bracket thingies help reduce or eliminate this issue? Or is it not the flexing of the bed but rather the vibrations of it that cause them to fail?
Regular truck frames are noodles in torsion. I have seen a frame flex so much when hitting the three wheel motion that the door couldn’t be closed once open until back on four wheels. Hitting things hard where the left and right wheels may hit something at different times causes the whole frame and bed to twist a little bit. Bed stiffeners won’t protect against this. The only thing you can do to stop the twisting is tube frame.
I have a nylon roll up cover that I’ve done some things with. Drifting on chunky dry lake beds and whoops and what not. It has lived but I can see it flapping around a lot in the mirror. I always roll it up before doing anything too wild. This style of cover is a lot more flexible so there’s not a ton of risk beyond the tubes that support it in the middle will dent the rails on the side.
Littlefx4
Fine with breaking my current one as an excuse to buy a different one.
No need for this. Just offload it to me and grab another. Btw, what brand/model is it? Better yet, doesn’t even matter; just let it go to a happy home and get the one you really want.
FloridaRaptor4me
Tampa, FL
I off-road with my Retrax and do jumps. I just roll it up next to the cab and tighten it down before and after the run as it comes a little loose. No issues to far but if I had to do it again I would think again about a bed cover.
