JL Stealthbox question
Pittmd
I'm upgrading the system in my 2011 SCAB with JL equipment. I'm going with C5 570's front and rear driven by the HD 900/5 amplifier and the cleansweep devices. I want to go with the Stealthbox for the sub but read on several threads here that it doesn't fit under the rear seat ot the SCAB. The JL web site says it will fit '04 and up SCAB. Does anyone here have the Stealthbox in their SCAB or know if it will fit properly? Thanks in advance
Harblar
Aberdeen, SD
Talk to forum vendor The Car Stereo Company. He deals a lot with JL equipment. I'm not sure what size sub you were planning on going with, but chances are he could build you a custom fit enclosure with sub for close to the same price as a stealthbox.
P
Pittmd
Thanks for the info. I guess I'm gonna have to go with a custom made box. Hey CSC, do you make a box that will go under the rear passenger seat that can use a JL 10" sub? If not, can you give me some info on the sub boxes you make and time frame to have one made? Again, thank you.
P
Pittmd
Wow.... You're quick. Was thinking only one sub that would be run off the HD 900/5 amp. Was hoping to keep space under driver side rear seat for jack and stuff. This may be a stupid question but can I run 2 subs with the single 500W channel from the amp? Also, where do people store the jack and other stuff if they put a box under the driver side rear seat?
here, on frf
Noah, Will your single 10" box fit in the stock location? Not ready to start with the audio stuff yet, just want ideas.
yep, i have a mold to make a 10" on the passenger side for both the supercab and crewcab.
you can run 2 woofers off if it, but each jl 10 wants to see 300watts rms, so it will be slightly underpowered. i have not seen what people do with the oem jack. a lot of people have a different floor jack in the bed
P
Pittmd
What 10" JL driver models do you recommend for and/or fit in you single and double boxes? Do you keep boxes in stock or would it need to be made?
here, on frf
the jl 10tw3 is the biggest woofer i can fit in a supercab. in the crewcabs, an audiomobile gts works very well. unfortunately i cant keep up with the boxes. i get orders faster than i can produce so there is a wait time. everyone is hand made here and test fitted so it takes a bit longer.
