JL Audio upgrade-wow
ISFast
Tulsa, OK
Did you guys have a chance to listen to Ryan's system with his new subwoofer at the Run? It sounded amazing so I ordered the same sub when I got home.
Sonicelectronix.com, it's an MTX Thunderform F150EX09FB10A-TN, $549... BUT you can hit "Make an Offer" button and type in $367... and it's free shipping!:rockit:
I just ordered mine! I didn't want to mess with building a box for my sub and mounting an amp. I already ran my 4ga wire for the stuff that I planned on putting in their but what a PITA. Anyways the factory system really isn't that bad except for the bass!
rylee44
Tulsa, OK
Best upgrade for the factory Sony setup that doesn't break the bank!
Rabnud
New Carlisle, OH
cant ever go wrong with JL.
THIS! When I didn't know ish from ish, I went to a sound shop in WA and got my first sub... a JL 10w0. I loved the sub! I tried a Memphis sub in another stang, it was alright, but when I upgraded to a 10w6v3, good lawd! I've owned several different car audio products in my time, JL takes the cake.:waytogo:
jpanayotov
Chicago, IL
Hey mcasseba,
Can you share the details on the LC2 hookup? Im a noob when it comes to audio hookups, but I'd like to do this same setup you got. Did you just use the 4 wires at the sub connector as your 2 channels going into the lc2? Also where did you tap for your constant 12v for your LC2?
Thanks in advance!
The Car Stereo Company
here, on frf
Hey mcasseba,
Thanks in advance!
what year vehicle do you have?
here, on frf
2012 f150
consant power - green/ red at ignition harness, also, red or blue/red at BCM in the pannenger kick panel..... also grey/red at radio
factory amp turn on - purple/red at radio. 8 pin plug, pin 4 also at factory amp
dual vioce coil woofer - purple/green (+) green/white (-) voicecoil #1 pins 1 and 9
green/purple (+) grey (-) voice coil #2 pins 2 and 10
at factory amp under center consloe
jpanayotov
Chicago, IL
Cool thanks for the info and the quick reply.
So would I be fine tapping the voice coil one as one channel into the lc2 and then voice coil two as the other?
Also, sorry for my ignorance on the subject.
here, on frf
yes, but dont leave the factory sub hooked up. those wires will go to the audio input on the lc2i. then the rca out to the amp. tuning depends on how you like the music to sound. for a 10 in woofer i usually start about 100hz on lowpass and adjust to you liking.
