Troutrad
The 12t ones are $109 for a set of two, before the 20% coupon, so like $180 for four.
You can get four of the 6t ones for $80, if you buy them in two trips. I’ve been trying to buy the 12t ones for a couple weeks, but my store hasn’t had any (recently switched design and haven’t gotten any of the new one yet).
I’m coming up on my first tire rotation, and thought I’d need them. I had a set of the 6t ones for my tractor, but I was worried about the max height. Doing the math on suspension travel, ground clearance, and that the jack points on the frame weren’t the lowest spot, said they probably wouldn’t work.
I tried it today, and the 3t Snap-On copy jack you mentioned (23 1/8” lift) and the 6t stands (23 5-8”), put to the frame, do get the front off the ground high enough to swap wheels, with almost 2” extra travel to spare.
That jack is a beast, and is on sale for $177 this weekend- that’s a crazy good price, for anyone looking for a capable jack.
Was at Harbor Freight today. They didn’t have the 12T but the sign was there for them but if the 6T’s work, I’ll just get them. Are the heights of the 6T’s adequate for the Rear Too? For the 12T, the height is 29 3/8 for Jack Stands.
Also... where are the front of the truck is the ideal location for the Jack and then the Jack Stands? Where is ideal location for Jack Stands in rear. Assume Diff best place for the Jack in the rear, correct?
