MattSVTM3
Hey All,
I've been having this ongoing issue with my Morimoto Elite XB55 kit that I'm using with my retrofitted headlights. Was wondering if any of you had had similar issues and any solutions.
Issue:
Bulbs flicker heavily on startup for a few seconds, and often one bulb no longer fires or sometimes both do not fire. I was left stranded once because the bulbs both died and wouldn't start back up.
Occurrence:
This only happens if I leave the headlights on auto and I turn on the truck. Additionally, if I turn on the truck and then turn the headlights to the on position within 10 seconds, then it happens. It seems that I am not able to turn the headlights on while the truck is powering all accessories.
My current solution:
If the bulbs do not fire, I cycle the headlights off and on, and then they fire up. Other solution is turning on the truck, and waiting 10 seconds until all accessories are on. Then turn on the headlights and they work fine.
What I have replaced so far:
- Wiring harness
- Ballast
- Ignitor
Before I replaced all those parts, I was left stranded without headlights on my drive home one night because the wiring harness fried after cycling the lights. I thought it was a bad ballast so I had everything replaced, reinstalled, and double checked the power and ground wires. This issue is happening again, and I do not want to be stuck without lights.
After speaking with The Retrofit Source and other friends, this is not something that should be happening. However, after hours of researching, I still do not know what is wrong. Any help would be appreciated to figure out why this is happening.
Thanks all!
Issue:
Occurrence:
- Wiring harness
- Ballast
- Ignitor
Thanks all!
