Is this normal?
dudmleh522
AZ
Just installed eibachs on my 2018. I did notice my tires are way too close to UCA. Is this normal? Will alignment fix this issue? Cant exactly remember how stock setup looked like.
By the way i have general grabber AT 315/70/17
Sig Fanboy
WV
It has to be due to factory offset wheels. I know you can’t install an aftermarket UCA with factory offset. I have 0 offset rims, no issues . I have no idea if an alignment will help.
dudmleh522
AZ
Thx for the info. So this is normal?
Sig Fanboy
WV
I had my stock wheels and tires for a couple of weeks after I put the springs on. I have a 19 and I know getting the UCA ball joint back into the spindle was a bear and the UCA would naturally be in a lower orientation relative to the tire with the longer spring. I guess I didn’t bother to look at how close it was….. but yes I think it’s normal after installing a longer spring .I do t think the UCA position can come any closer to the tire and wheel throughout its range of motion …. Keeping in mind I’m no expert.
dudmleh522
AZ
also front measures little over 41" and rear with icon (option 3) with 500lb i am at 43.75"
