Is it worth it?
John813
PSL/Jupiter
Thanks for your input. I have to check with the seller but would those CarFax or AutoCheck reports indicate whether the car's had the required maintenances?
Is there a way to determine whether the transmission and other parts have been serviced?
Thanks
David
If I recall correctly, only if he had them serviced at a dealership. think I've seen maintenance records show up on Carfax from places like PepBoys, but not 100% sure.
Transmission is an item where you'll hear things all over the place. Ford claims it's good for the life of the truck, and you don't need to change it.
Others may change the fluid every 20-50k miles for piece of mind.
I flushed mine 13k miles ago, and haven't had any issues since.
If there are no records on Carfax/Oasis(you can get it at a Ford dealership) then you can ask the seller if he has any records/receipts of him doing the work.
