is forscan considered a tune for warranty
A
alangsam1
Florida
not talking about the procedure. talking about the fact that you would ever need it in the first place.
andy556
ohio
If I reset the transmission table via Forscan, will I need to follow a reteaching procedure or do I just drive the truck and let it relearn my driving style. Thanks in advance….
andy556
ohio
Thanks…..does this improve the transmission. Mine just jerks/jumps forward when putting into drive. I’ve only had the Truck a week, love it but concerned about this issue.
FordTechOne
Detroit
The procedure needs to be followed, otherwise the transmission will not learn correctly and you’ll induce other concerns.
K223
Florida
I imagine there is no way outside of the dealer to obtain the factory base table/image that is flashed on to a new BCM at the factory?
A
alangsam1
Florida
this process with Forescan on IOS and a bluetooth OBD11 Adapter works really well and is easy to set up.
Donovan
DC
The risk reward is worth it. A lot of nice features to gain and you can disable some lousy ones. I think chances are small that your dealer would give you a problem. Just back up everything as directed in the documentation.
Explain some of the rewards?
