- Joined
- Dec 16, 2016
- Posts
- 18,288
- Reaction score
- 28,826
People have had their warranty effected from making changes w/ forscan- threads on this forum I believe.
Which people?
When the transmission adaptive tables are reset, there is a very specific drive procedure that needs to be performed afterward. Otherwise the transmission will not re-learn properly.So I was able to use Forscan lite on IOS to rest the transmission adaptive tables. It completely fixed the hard 1-2 and 2-3 shifts. Amazing. lets see how long it takes to come back. However I am very satisfied with the tool and the bluetooth OBD adapter. Now to disable the engine sound enhancement.
TechWhen the transmission adaptive tables are reset, there is a very specific drive procedure that needs to be performed afterward. Otherwise the transmission will not re-learn properly.
Adaptive Learning Drive Cycle
Programming
NOTE: Perform the adaptive learning drive cycle on a level road surface.
- Using the scan tool, clear the DTCs (Diagnostic Trouble Codes) and Transmission Adaptive Tables.
- Drive the vehicle until the engine and transmission reach normal operating temperature.
- Accelerate from a stop with light throttle (15%) ensuring that upshifts 1st through 8th occur at engine speeds between 1300-1600 rpm.
- Continue to accelerate (may apply slightly more throttle after 7-8 upshift at 32-38 mph (51-61 km/h) until you achieve 55 mph (88 km/h) and the 8-9 and 9-10 shifts complete.
- Brake very gently to a complete stop and hold foot on brake for five (5) seconds.
- Shift the transmission to Neutral. Wait 1 second.
- Shift the transmission to Reverse. Wait 2 seconds.
- Shift the transmission to Drive. Wait 2 seconds.
- Repeat Steps 3 through 9 six additional times.
Thanks for posting this, although it seems excessive and I'm not sure where many techs or even owners will have the place to run thru 7 cycles in a row. Is this just suggested, or is there a PID to show learning has completed?When the transmission adaptive tables are reset, there is a very specific drive procedure that needs to be performed afterward. Otherwise the transmission will not re-learn properly.
Programming
I'll have to give this a try. Thank youWhen the transmission adaptive tables are reset, there is a very specific drive procedure that needs to be performed afterward. Otherwise the transmission will not re-learn properly.
Programming
No PID, as the leading does not actually “complete”. This procedure essentially establishes a base table from which the transmission will continue to learn/adapt.Thanks for posting this, although it seems excessive and I'm not sure where many techs or even owners will have the place to run thru 7 cycles in a row. Is this just suggested, or is there a PID to show learning has completed?
That’s the case with any modern electronically controlled transmission; the procedure is not unique to 10R.well i'll be a great test case. it's unfortunate that after 40 years of all kinds and types
vehicles this transmission is so
unrefined it needs tables to be reset to get it to be consistent shifting.
