IRONMAN
Well-Known Member
Step 1
Building the sockets for a quick release Rack.
Purchased a 2' peice of tubing that allows the 1 3/8" tubingto slide into it.
I cut 4 (1 1/2') peices.
Next I drilled out ends to cap off the tubing.
Ground down all the rough edges and set it up for welding together.
Place a socket in the center of the tubing that allowed the ends to be slightly recessed in.
Tacked it up and welded it together. Then I ground it down to make a nice finished look.
Next I removed the bed bolt and ground down the edge to allow me to remove the washer.
Drilled out the hole in the socket to the bolt size and bolted it to the bed.
Ready for step 2...
Ready for step 2...
