Intermittent grinding/humming
Los Angeles
Hi All,
Original Owner of a GEN2 2019 Ford Raptor SCREW, 79K miles (truck is stock).
I'm trying to pinpoint an intermittent humming/grinding noise before it becomes a bigger issue.
Symptoms:
  1. Faint grinding noise from the front left wheel when turning fully to the right and in reverse (e.g., pulling out of a parking spot). The noise is light but vibrates through the floorboard, gas, and brake pedals.
  2. Light humming/grinding/binding when coming to a stop (~5 MPH), especially when the truck is cold. This vibration also reverberates through the floorboard, gas, and brake pedals.
  3. Excessive winding/grinding in 4A under moderate to heavy acceleration, heard from inside the cab. The noise disappears when switching back to 2WD. While some 4WD noise is expected, I compared it to another 2019 Raptor, and mine is about twice as loud. Could this be related to my other issues?
I suspect wheel bearings, hubs, hub actuator, or CV axle, but I’m not certain. The truck is under warranty, but despite multiple dealership visits, they can't replicate the issue so no further investigation gets done.
Any insights or suggestions would be greatly appreciated—this is driving me crazy!
CecilK12
Monrovia Indiana
My 2018 has this same thing going on. I thought initially it was the IWE valve. That didn’t resolve it. I seem to have a slight wheel hop as well.
Michigan
Hi All,
Symptoms:
I have the same thing going on and plan on taking it to the dealer within the next week or two. I'll keep ya posted if they find the problem. Please post any updates you have in the meantime. Thanks.
stevengreene310
Los Angeles
Great, thanks keep me posted. I am going to try and diagnose this more in the next few weeks as well. I plan to take it to the dealership sometime next week and will let you know what comes of it.
SilverGen1
Midland MI
Definitely the hub, actuator, and cv not meshing together properly, sucks that your dealer won't just replace the parts. I also replaced the entire vacuum harness, and that had helped, but I have Gen 1, so it was obviously older than yours
stevengreene310
Los Angeles
I wish they would just take it apart and inspect it. I have spent so much time back and forth to the dealer without them really doing anything. Going to really try and press them to dig into this more on my next trip.
EastEndAngler
Long Island, NY
Following as I've got the same symptoms. Would love to to know how to translate this into Service Advisor so that it actually gets looked at. Thinking of supplying the pin-point test / terminology for the IWE's as a starting point.
stevengreene310
Los Angeles
Update: I was able to recreate the symptom I’ve been experiencing. Today, while exiting the freeway at about 50 MPH on a right-hand curve, the grinding noise appeared through the curve and was a lot more pronounced. I believe since weight was shifted to the left hand side of the truck through the curve, this put more pressure on the front left tire/hub.
The noise sounded exactly like other typical IWE hub grinding sound people have posted before. I believe either my hub or hub actuator is at the early stages of failure, and will continue to get worse.
I’m glad I was able to narrow it down, as this will help me demonstrate the issue to the dealership during my next visit. I’ll provide an update once I have a chance to take it in.
