Waterfowler41
In this video I walk through how to install the hot and cold pipes from CV Fabrication in a Gen 3 Raptor. Figuring out which pipe went where took the longer until I realized the two pipes with the threaded inserts attach to the turbo outlets. Once they epiphany came to me, it was smooth sailing so hopefully this video at least speeds up that portion of the install for you all.
A couple of tips:
1. Get a cordless 1/4 ratchet. It will make your life much easier and you will be able to remove 90% of the band clamps (there's a ton). If not, plan for some really sore hands.
2. Remove the pipes in this order: cold pipe, passenger hot pipe, and then driver's hot pipe. Reinstall in the opposite order. You need all the room you can get to install the drivers side pipe.
Any questions on this one let me know!
A couple of tips:
