Identify This Part - Underside of Bed Box - Vibration Damper
vanilla_gorilla
NorCal (Sacramento)
Mystery part...
Located on top of the frame, driver side, next to the spare time, is a heavy piece of metal that wiggles.
I removed it...just wondering what its for. It's gotta weight 15/20lbs...
Deleted member 12951
Guest
Mystery part...
So funny, I found that too last week, didn't remove it but was going to take a picture and post it here asking what it was too. Glad you already did, I am definitely curious to as there isn't one on the other side.
EDIT: Found it, it is a Damper Assembly. Suppose to help bouncing of the bed. Retail is, get this.......$506 but at Tasca you can get it for only $335, lol
Better put that expensive part back on!!
TSB for it (guess Ford decided to keep it on for future years):
Tsb 07-5-11 Vibration/hop At 40-48 Mph - (8.0 Hz) - Trailer Hitch Equipped Vehicles Only
FORD:
2005-2007 F-Super Duty
ISSUE:
Some 2005-2007 F-Super Duty vehicles with a long wheelbase of 156", 158", or 172" (396, 401, or 437 cm) and equipped with a trailer hitch may exhibit a vehicle vertical vibration, often described as "hopping", on smooth or coarse road surfaces in the 42-48 MPH (68-77 Km/h) speed range. Although this behavior is considered normal for an over 8500 GVW truck, some customers may be sensitive to the concern.
ACTION:
To improve the 42-48 MPH (68-77 Km/h) vertical vibration, follow the instruction sheet included in the Damper Service Kit.
NOTE: THE INSTALLATION OF THIS DAMPER WILL NOT IMPROVE RIDE ON SEGMENTED CONCRETE HIGHWAYS, STEERING WHEEL VIBRATION/SHIMMY, OR GENERAL HARSH RIDE CONCERNS.
PART NUMBER PART NAME
5C3Z-5D008-A Damper Service Kit
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
070511A 2005-2007 F-Super Duty With Trailer Hitch: Install The Damper Service Kit. 0.6 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
5D008 42
Flamingo Racing
Arizona
Was installing rear lighting and saw the mystery weight. Joined the forum today to search for an answer. Already a helpful site. I will definitely keep an eye and ear out for failure. Next time under there, the extra lbs may be removed anyway.
Bilwil
Las Vegas, NV
What is this balancer on the rear frame?
The bed has been pulled and I found this. How critical is it to retain? Harmonic balance to minimize vibration or sound?
Any insight will be greatly appreciated.
Thanks!
Bill
Kmandoske
Bartlett, IL
i took mine off when I had the bed off as well. All the rubber bushings were torn apart anyway. some sort of harmonic balance I guess.
