rojo212
How much disassembly/assembly is required to adjust the leaf springs? I tow with my truck from time to time and want to be able to tow when I need to, but not have the extra lift for daily driving and parking garages.
Is a sprung under kit in the works in the future?
With the increased up travel, will 37's have an issue with the pinch weld in the rear?
I thought most when going to 37's will bend that over or at least address that in the rear already?
It's separating the pack and changing out a leaf or adding a leaf in to the pack. You can take a look at the instructions on the Product page for the springs.
We towed this trailer with our springs installed at the standard setting 3000 miles (ICON > TRR 2014 > Moab, UT > ICON) with only the use of a weight distribution hitch and it did just fine. It was not heavily loaded, but did have displays and other items for both events.
Thank you for the info. This is the trailer I towed to from Houston > Raptoberfest > Houston.
It was roughly 300 miles round trip. The truck was riding on the bump stops with the 7,000 lb load with a roughly 500-700 lb tongue weight. Would the standard setting be able to handle this?
Also, you mention an increase in height over 0.75" lift over stock on the standard setting, is this purely being 0.75" taller or does this 0.75" of lift include the removal of the stock 2" rear blocks?
