Well, got everything mounted and working (other than removing the diodes to transmit on commercial frequencies). I don't like how the bracket turned out, but now that I know what's wrong with it I'll make a new one this weekend and remount. But, it will be in the same place, just a little lower profile and angled towards the center of the truck (sticks out too far for my taste).
Here are the last few pics.
Making the bracket.
It fits.
A little plasti-dip
Then mounted and ground down the mounting HW.
I ran the antenna cable down the inside of the bed rail, out one of the holes between the bed and the cab and then into the filter/vent in the back of the cab. No need to drill holes. The filter/vent is actually open besides a little filter that covers the vent. So, I came in through that. To do that I had to lay down the rear seats which took a second to figure out (thanks FRF...note laying down the rear seats is different between SCAB and SCREW).
Down the inside of the bedrail/bedside:
Lay down the seats, pull back the padding and there is a vent in the rear of the cab.
Ran the cable behind the matting and down along the floor between the seats and molding. Before the cable rounds the seats, I tucked under the molding and then ran in the floor gutters of the rear and front passenger side.
Tucked everything back in and snapped everything back together and we're good to go. Just need to terminate the antenna cable and plug it in.
I had never made the TR259 connectors on RG58 cable before. So, I youtubed a couple of videos and figured it out. I bought a couple extra connectors and adapters in case I f'ed up the first one or two, but I ended up only needing the first connector (hey, I can solder and cut cable with the best of them). I left some extra antenna cable just in case a relocation was needed (wrapped it in figure eight) and plugged everything in.
Next, I wanted to extend the microphone cable. I stopped by ham radio outlet and they wanted 90 bucks for an icom extension cable. Guess what...a normal cat5 ethernet cable will work. I went home and made my own mic cable to length. Saved at least $85 on that deal.
Here's a couple of shots of the different antenna. I cruised around town with the small one mounted today with the radio scanning and picked up a bunch of stuff. I'll save the long antenna for when I'm offroading or have a need for more gain and transmitting power.
Short:
Long:
Thanks for your patience with all my pics. It helped me sort out the install.
