John Butler
I have a 2 car garage. Work bench’s and my wife’s Saleen take up the spaces. With serious complications if I try to garage the Raptor.
Isn’t that always the problemMy garage is 20x20 in the bay area.. it just doesn't fit... I leave it at another house with a longer garage. Length is my problem....
I garage mine and it barely fits stock. My garage is plenty long but only 79 inch clearance....Fits like a glove. It doesn't sound like you actually have an issue...even if you put on a leveling kit. Larger wheel or tires aren't something you should do to a truck you paid 70k+ primarily for the suspension setup. Larger wheels or tires will just reduce MPG, increase weight, reduce acceleration times and provide barely any additional clearance. The trucks are designed and you are paying up for a perfect suspension tuned for what the truck is designed for. Leave em at 35s with 17" rims. Spend your money on a tune, Xpel PPF, bed cover, intercooler/air intake....park it in your garage and drool every time you walk out there![]()
So did you measure top of garage or overhang on garage door?
what I did was ask in a local group if anyone had one that I could test fit in my garage. Worked well, since I was able to verify that it would fit once I had it where I wanted it.
I would have your friend with the leveled, 37s measure their garage height (make sure to measure to overhang and not the top of the garage it’s self, this way you will know if your clearance is the same if it will fit.
hope that helps!
