I think I have the dreaded Cam Phaser Rattle
FordTechOne
Detroit
yes but did they fix the issue? ive seen many trucks after this build date with the exact same issues as well as a couple 2020s posted on facebook with the issue....just because they stamp a new part number on something doesn't mean it fixed the problem
The phaser locking pin mechanism was completely redesigned to eliminate the issue that was occurring. That doesn't mean out of millions of vehicles with 4 phasers each that there will never be another defective one. Don't put too much weight on people self diagnosing their vehicles over the internet; that's a slippery slope. I've seen everything from turbocharger wastegate rattle to transmission pump noise misdiagnosed as a cam phaser concern.
Gdog
Colorado
I've read about cam phasers issues since I got my early 2017 built truck. Is this issue just bad luck on certain trucks or what? No issues with mine at all. Of course I don't drive it like I stole it either. Thanks for your feed back
FordTechOne
Detroit
Only a certain percentage of phasers were affected by the issue, so not every truck in the population will experience a concern. If you have an early build '17 and haven't had an issue by now, you should be fine.
Gdog
Colorado
Thank you. Truck was actually built in oct 2016. Visited the in laws in Dearborn and visited the rouge plant in nov of 16 to see if could get a glimpse of the dreaded ramp 59 everyone was talking about. Highly recommend the tour!! What a awesome place. Thanks again
MntBrew
West Michigan
I believe it was on this forum that a member posted a video of a Ford tech disassembling one his phasers and said the locking pin was made of plastic. Do you know if the original GEN 2 phaser used a plastic locking and is the redesigned locking pin made out of metal?
FordTechOne
Detroit
No phaser has ever had a plastic locking pin. The original was made of metal, and the redesigned part is also made of metal. Not sure how such a rumor got started.
MnFlyer
MN
About 3:25 in the tech calls it “hardened plastic”
I assume that’s the locking pin that was broke?
MntBrew
West Michigan
That's the video I was referring too. However after watching it again, it appears as though the pin at the 1:52 mark is the locking pin and it does look like it's metalic but then at the 3:37 mark the tech calls the pin that they're looking at the locking pin and says that it's made out of hardened plastic. Maybe it was just a case of misidentification on the part of the tech but it was a question that has been buggin me for the longest time and no one had asked it yet and I had to know.
